Windows 10 Fully turn off display on 0 brightness.
Heera
Before reinstalling windows, my laptop's monitor would turnoff whenever I set the brightness to 0. Now with a clean install of windows, 0 brightness is just very dim. I would like to know if there is a way to get this feature back, as it was very useful. Any help would be appreciated.
Normal behavior of 0 brightness is very dim. It could of been some utility that came pre-installed.
I'm assuming your intent is to leave the computer on and it either runs something in the background or login remote. You should be able to set the screen to turn off in the power plan.
