Need help deciding on 2 components for new pc build
brkkab
I'm currently in the process of getting parts for a new computer build.
So far I have a Asus Maximus VIII Hero mobo and a Samsung 850 EVO 500GB. M/2 ssd for it. I'm also going to be re-using the Seagate Barracuda 3.0TB h.d , Intel 530 Series 400GB ssd (for Games), Lite On DVD-RW, Lite ON Blu-ray burner and memory card reader from my current pc.
I'm also going to be getting a NZXT Phantom 820 case. G-Skill Ripjaws-Z DDR 4 3200 ram (32GBS) and a Corsair HX-1000i psu for the new pc.
I need suggestions between the following part's for the new pc.
The heatsink is either going to be a EK-XLC Predator 240 or a Corsair Hydro Series H-100i GTX.
With either one, I'll be using 4 EK-Furious Vardar FF5-120 (3000rpm) fans in push/pull.
I also need help deciding between 2 GeForce GTX 4.0GB or 2 AMD Radeon 390X 4.0GB video cards.
I'm ordering a Intel Core i5 6600K cpu on Thursday and eventually plan on upgrading it to a Core i7 6700K in early 2017.
Keep in mind, I'm on permanent disability (Social Security) for life and can't afford to spend over $300.00 on a part/s in a month.
The pc won't be built until May as I won't have all parts until then minus the new video cards.
I'll be using my current GeForce GTX 760's until then, but they need to go back inn this pc, so I can sell it.
All suggestions appreciated between the AIO's and video card's.
P.S. PC will be running Windows 10 Pro x64.
I'm actually hoping for Tuesday or Wednesday. I have medical stuff Monday & Thursday.
Though, when I ordered my current pc's case, I received it the next day on a Saturday morning.
I very well may be building it tomorrow. I'll know sometime tonight when my tracking number is updated by FedEx.
I already have the number, they're just not as good as UPS or the USPS, in the tracking department. It probably won't give me any results until 11:00 P.M.
brkkab
An image from 'Need help deciding on 2 components for new pc build'. Error message showing 'esrv.exe' failed to start with code 0xc0000135 on Windows.
New Creators Update bug. I have no idea what this file is listed in the error message.
ussnorway
Windows Forum Team
ok well that process will try to record what powerplan you use and send it back to homebase... you can uninstall the update utility (short term fix) or look for an update which Intel should have any day now or even just ignore it as it doesn't do anything bad
brkkab
OK, I'll have to do that later.
GOG, emailed me again. GOG Galaxy still doesn't work for me.
They have a downloader, which is nice, but s_s_s_l_l_l_o_o_o_w_w_w.
I have Crysis downloaded and installed now.
Now, I'm waiting forever for the Witcher 3 GOTY to download, so I can install it.
brkkab
The Witcher 3 GOTY is installed & Intel Driver Update Utility is uninstalled.
Error message is gone.
brkkab
Thanks ussnorway.
Maybe, I'll actually get around to putting my Predator this week or weekend.
brkkab
Next week is a definite no for that. 3 differnet day's with appointments.
Monday: Hospital's Lab.
Wednesday: Endocrynologist for diabetes.
Thursday: Orthopedic Surgeon.
3+ miles of 1-legged hopping between the 3.
brkkab
New AMD Crimson ReLive 17.4.2 driver released yesterday.
Find the latest Graphic driver releases and download links here:
Graphic Drivers
brkkab
I did a clean install of Creators Update yesterday. Now GOG Galaxy and everything else is working so far.
I just have to re-download all my magazines later tonight from Zinio.
This time around I left Raxco's Perfect Updater 2.0 uninstalled.
Maybe that was the issue ?
The Sunday will be weekly backup and system image time.
ussnorway
Windows Forum Team
could be a conflict... they both want the same port?
anyway nice work getting it sorted
brkkab
Yeah probably. I was off on when I did the clean install. It was actually Wednesday. After I got Windows installed, updated, driver installs and GOG Galaxy installed the power went out for a few hours in my area.
I already had Crysys, The Witcher 3: Wild Hunt GOTY, Origin, Need For Speed: Most Wanted installed.
Then Origin was downloading Crysis3 & Titanfall Deluxe when the power went out.
Redid those and everything else Wednesday night, Thursday and just got my Zinio magazines done.
I forgot I had to get my offline maps, too.
They're done now, too.
So far, so good.
I did notice a Creators Update bug on this install.
This time I also setup a pin for logging into Windows 10.
That worked fine Wednesday & Thursday, but not today.
I'm back to re-using my Microsoft account password for logging in, as the pin login fails.
brkkab
It had to have been Raxco Perfect Updater 2.0. The only thing I didn't install. For the hell of it I ran Windows Backup & System Image a day early and both completed successfully this time.
nmsuk
Have you checked those backups as the windows one fails restoring for me on creators update. Luckily acronis 2017 does a fine job.
brkkab
Actually since 1995, I've been lucky, I've only ever had to restore any files or folders from a backup twice and restore 1 system image.
The 2 backup episodes were only because of replacing a hard drive both times.
brkkab
Actually, I accidently did a mistake in Storage Sense this morning and let it delete my downloads. I thus, found out my backup worked, as it restored my downloads for me. Then I only had to re-download GPU-z, as a new version was released yesterday.
I also, purposely deleted my downloaded themes from Vista, 7, 8 and 8.1, as Creators Update puts Windows Themes in the Store and their all free, so far.
They don't have all the themes I had before, but it's roughly 3/4 of them.
I'm just using a different one now as the Sailing theme isn't in the store yet.
nmsuk: The new RX 580's don't look much better setting's wise, compared to the RX 480's.
The RX 780 or RX 880 will be out before I think of upgrading.
When I do a new video card upgrade in 2 years, I'll probably do a monitor upgrade right after it.
brkkab
nmsuk: I noticed something in Windows Backup when I went to restore them. They didn't at first. They're a new check box that needs to be checked first, before it will actually restore anything.
