Windows 7 PROBLEM WITH MY MOUSE
DTCZSR
Location
FRESNO, CALIFORNIA. USA
I have a problem with my mouse it keeps freezing up on me, I have to do the 3 finger salute (ctrl+alt+delete) and then sometimes the mouse will work again but most times it does not work. I have uninstalled the mouse- did not work. I even reinstalled the os and that did not work either, now I'm stuck on windows update searching for them, just letting it run 2hours now and still searching and can not even use the mouse. I also tried 5 different brands of mice, still have a locked up cursor. even tried every usb port, I am running windows 7 ultimate 32bit. can someone please help resolve this problem. thx very much
could you post a little more detail on:
What your system specs are?
Are your USB/chipset drivers up to date?
Have you tried using a PS/2 port or converter?
Have you checked for malware?
everything is always updated, malware & virus free. diagnostics are ran every day, tried using PS/2 ports
and here is my gaming pc setup:
WINDOWS 7 ULTIMATE 32BIT & 64BIT DUAL BOOT OS
6th Gen Intel® Core™ i5-6600K
6M Cache, UP TO 3.90 GHZ, Intel®
HD Graphics 530 - BX80662I56600K
3 ViewSonic 46" Class LED Commercial Display
LED Backlit LCD Flat Panel Display, Full HD 1080p
1920x1080 Resolution, 1x HDMI, 16:9, 4000:1 - CDE4600-L
Hp Quadro K6000 Graphic Card
12 Gb Gddr5 Sdram - Pci Express 3.0 X16
Displayport - Dvi C2J96AT
Kingston 64GB Kit (4x16GB) DDR4
2133MHz, 1.2 V, ECC, CL15, 288-Pin
Registered - KVR21R15D4K4/64
6 SEAGATE 5TB HARD DRIVES RAID ARRAY
MSI Z170A Gaming M7 ATX Motherboard
Intel® Z170 Express Chipset, SATA 6Gb/s
PCIe 3.0, HDMI, DisplayPort, Multi-GPU
USB 3.1, USB 2.0, Qualcomm® Killer™
E2400 Gigabit LAN Controller-Z170A GAMING M7
LOGICOOL HID-COMPLIANT CORDLESS MOUSE & KEYBOARD
HP OFFICEJET 6700 NETWORK PRINTER
Bose® - Companion® 5 Multimedia Speaker System (3-Piece)
NZXT H440 Silent Mid-Tower Case
Corsair Hydro Series H100i Liquid CPU Cooler
Antec HCP 1300 Platinum Modular PSU – 1300W Continuous Power
80 Plus Platinum, 16 Pin Socket, 20+8 Pin MBU Socket
4 x +12V Rails, 10 x PCI-E, 135mm DBB Fan, NVIDIA SLI Ready
HCP-1300 PLATINUM
nice pc..
The only thing that looked a little suspect was the Logicool Mouse and keyboard. I don't know this brand although you mention using at least 5 different brands. Did any of these include any wired mice or were they all cordless?
nice pc..
The mouse & keyboard are Logitech items, and I have tried both wired & wireless. also I forgot to mention that every time I re boot my pc my mouse settings revert back to default. I always have the mouse pointer options set to fast speed, enhance pointer precision box checked. but I have to set them again.
Apologies for all the questions but did the issue get gradually worse or just start one day? Can you remember if it coincided with any updates or new applications? The reason I ask is because of you pressing the 3 finger salute it's probably stopping whatever is hampering the mouse. I'd look through your applications and see what you added most recently. It might even be a combination of things?
it happened all of a sudden after I turned on my pc the next day,
and now since I have been trying to fix my mouse problem with my mouse 2 more problems have come up, the first one is my mouse pointer options settings revert back to default settings when I re boot my pc. the settings that I like to have are: select a pointer speed I set to fast and I have checked the first 2 boxes, those are the ones that keep changing. the other error that that I am getting when I re boot is Microsoft visual c++ runtime library: this application has requested the runtime to terminate it in an unusual way, please contact the application's support team for more information.
I am also hoping that when I get my upgrade to windows 10 it will fix all my problems if I do not get them fixed before the upgrade.
If you open add and remove programs you'll see which which visual c++ runtime libraries you have installed. You can then download them again here and run the repair option:
https://support.microsoft.com/en-gb/kb/2977003
These libraries are needed by certain apps/games. What about using system restore? Is there a point you can go back to? If not I'd try installing the C++ libraries again.
Same here to be honest.. :)
did not work, downloaded apps that you said to install. re booted repaired rebooted again and still the same error. I hate this when nothing works to fix a problem. how about doing remote desktop maybe if you take over you could get it done. this is my wifes pc and she is not home right now.
Can you check the event logs and see if anything is amiss also which anti-virus app are you using?
Microsoft security essentials, is there anyway to do remote desktop or can we talk on the phone? because event logs has a lot of errors, to much to type but here it is. I hope I did this right.
Level Date and Time Source Event ID Task Category
Error 9/20/2015 1:21:52 AM SideBySide 33 None "Activation context generation failed for ""C:\Program Files\Phantom EFX\ReelDealLive\WorldTour\Launcher\ReelDealAdventureWorldTour\RDALauncher.exe"". Dependent Assembly Microsoft.VC80.MFC,processorArchitecture=""x86"",publicKeyToken=""1fc8b3b9a1e18e3b"",type=""win32"",version=""8.0.50727.4053"" could not be found. Please use sxstrace.exe for detailed diagnosis."
Error 9/20/2015 1:03:05 AM Application Error 1000 (100) "Faulting application name: EasyShare.exe, version: 2.0.4.302, time stamp: 0x3fdb7652
Faulting module name: msvcrt.dll, version: 7.0.7601.17744, time stamp: 0x4eeaf722
Exception code: 0x40000015
Fault offset: 0x0005620a
Faulting process id: 0x1368
Faulting application start time: 0x01d0f37a68fc1d0c
Faulting application path: C:\Program Files\Kodak\Kodak EasyShare software\bin\EasyShare.exe
Faulting module path: C:\Windows\system32\msvcrt.dll
Report Id: 054047ee-5f6e-11e5-9ae8-40167eb40d58"
Error 9/20/2015 1:02:11 AM Microsoft-Windows-WMPNSS-Service 14332 None Service 'WMPNetworkSvc' did not start correctly because CoCreateInstance(CLSID_UPnPDeviceFinder) encountered error '0x80070422'. Verify that the UPnPHost service is running and that the UPnPHost component of Windows is installed properly.
Error 9/20/2015 1:00:20 AM Microsoft-Windows-WMPNSS-Service 14332 None Service 'WMPNetworkSvc' did not start correctly because CoCreateInstance(CLSID_UPnPDeviceFinder) encountered error '0x80070422'. Verify that the UPnPHost service is running and that the UPnPHost component of Windows is installed properly.
Error 9/20/2015 1:00:17 AM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Homegroup Log"" failed to start with the following error: 0xC0000035"
Error 9/20/2015 1:00:10 AM Microsoft-Windows-WMI 10 None "Event filter with query ""SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA ""Win32_Processor"" AND TargetInstance.LoadPercentage > 99"" could not be reactivated in namespace ""//./root/CIMV2"" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected."
Warning 9/20/2015 12:59:36 AM Server 2511 None "The server service was unable to recreate the share JIMS MOVIES because the directory X:\JIMS MOVIES no longer exists. Please run ""net share JIMS MOVIES /delete"" to delete the share, or recreate the directory X:\JIMS MOVIES."
Error 9/20/2015 12:59:17 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Warning 9/20/2015 12:58:30 AM Microsoft-Windows-WLAN-AutoConfig 4001 None "WLAN AutoConfig service has successfully stopped.
Warning 9/20/2015 12:58:22 AM Microsoft-Windows-User Profiles Service 1530 None "Windows detected your registry file is still in use by other applications or services. The file will be unloaded now. The applications or services that hold your registry file may not function properly afterwards.
DETAIL -
10 user registry handles leaked from \Registry\User\S-1-5-21-946150505-1243804552-548205274-1000:
Process 2084 (\Device\HarddiskVolume2\Program Files\TuneUp Utilities 2014\TuneUpUtilitiesService32.exe) has opened key \REGISTRY\USER\S-1-5-21-946150505-1243804552-548205274-1000
Warning 9/19/2015 11:49:25 PM Microsoft-Windows-RestartManager 10010 None Application 'C:\Program Files\FileHippo.com\FileHippo.AppManager.exe' (pid 3028) cannot be restarted - Application SID does not match Conductor SID..
Error 9/19/2015 2:54:29 PM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Homegroup Log"" failed to start with the following error: 0xC0000035"
Error 9/19/2015 2:53:15 PM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 9/19/2015 2:52:59 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 9/19/2015 12:48:13 PM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Homegroup Log"" failed to start with the following error: 0xC0000035"
Error 9/19/2015 12:47:01 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 9/19/2015 8:30:30 AM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Homegroup Log"" failed to start with the following error: 0xC0000035"
Error 9/19/2015 8:29:24 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 9/19/2015 8:06:33 AM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Homegroup Log"" failed to start with the following error: 0xC0000035"
Error 9/19/2015 8:05:49 AM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 9/19/2015 8:05:31 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 9/19/2015 7:26:36 AM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Homegroup Log"" failed to start with the following error: 0xC0000035"
Error 9/19/2015 7:25:14 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 9/18/2015 8:30:52 PM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Homegroup Log"" failed to start with the following error: 0xC0000035"
Error 9/18/2015 8:29:04 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 9/18/2015 6:48:02 AM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Homegroup Log"" failed to start with the following error: 0xC0000035"
Error 9/18/2015 6:45:44 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 9/17/2015 1:49:11 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Homegroup Log"" stopped due to the following error: 0xC0000188"
Warning 9/17/2015 1:49:11 PM Microsoft-Windows-Kernel-EventTracing 4 Logging "The maximum file size for session ""Homegroup Log"" has been reached. As a result, events might be lost (not logged) to file ""C:\Windows\Logs\Homegroup\homegrouplog.etl"". The maximum files size is currently set to 5242880 bytes."
Error 9/14/2015 8:01:30 AM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Homegroup Log"" failed to start with the following error: 0xC0000035"
Error 9/14/2015 7:59:42 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 9/13/2015 8:29:41 PM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Homegroup Log"" failed to start with the following error: 0xC0000035"
Error 9/13/2015 8:29:41 PM Microsoft-Windows-Kernel-EventTracing 2 Session "Session """" failed to start with the following error: 0xC000000D"
Error 9/13/2015 8:27:46 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 9/13/2015 4:58:08 PM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Homegroup Log"" failed to start with the following error: 0xC0000035"
Error 9/13/2015 4:56:02 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 9/11/2015 12:41:38 PM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Homegroup Log"" failed to start with the following error: 0xC0000035"
Error 9/11/2015 12:41:37 PM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Homegroup Log"" failed to start with the following error: 0xC0000035"
Error 9/11/2015 2:18:06 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 9/3/2015 2:21:38 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 9/3/2015 1:40:54 AM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""BuiltInRestoreUITracing"" failed to start with the following error: 0xC0000035"
Error 9/3/2015 1:34:48 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 9/1/2015 10:44:34 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 9/1/2015 9:04:44 AM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 9/1/2015 9:04:23 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 9/1/2015 8:59:54 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 8/30/2015 8:32:00 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 8/28/2015 8:07:25 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 8/28/2015 5:48:32 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 8/28/2015 4:38:18 PM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Circular Kernel Context Logger"" failed to start with the following error: 0xC0000035"
Error 8/28/2015 4:38:17 PM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Circular Kernel Context Logger"" failed to start with the following error: 0xC0000035"
Error 8/28/2015 4:38:16 PM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Circular Kernel Context Logger"" failed to start with the following error: 0xC0000035"
Error 8/28/2015 4:38:15 PM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Circular Kernel Context Logger"" failed to start with the following error: 0xC0000035"
Error 8/28/2015 4:38:14 PM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Circular Kernel Context Logger"" failed to start with the following error: 0xC0000035"
Error 8/28/2015 4:38:13 PM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Circular Kernel Context Logger"" failed to start with the following error: 0xC0000035"
Error 8/28/2015 4:38:12 PM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Circular Kernel Context Logger"" failed to start with the following error: 0xC0000035"
Error 8/28/2015 4:38:11 PM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Circular Kernel Context Logger"" failed to start with the following error: 0xC0000035"
Error 8/28/2015 4:38:10 PM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Circular Kernel Context Logger"" failed to start with the following error: 0xC0000035"
Error 8/28/2015 4:38:09 PM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Circular Kernel Context Logger"" failed to start with the following error: 0xC0000035"
Error 8/28/2015 4:38:08 PM Microsoft-Windows-Kernel-EventTracing 2 Session "Session ""Circular Kernel Context Logger"" failed to start with the following error: 0xC0000035"
Error 8/28/2015 1:36:11 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 8/9/2015 2:55:40 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 8/9/2015 12:34:38 AM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 8/9/2015 12:34:13 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 8/6/2015 6:53:29 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 8/6/2015 6:48:48 AM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 8/6/2015 6:48:28 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 8/6/2015 6:39:58 AM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 8/6/2015 6:39:40 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 8/6/2015 6:32:23 AM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 8/6/2015 6:31:56 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 8/6/2015 6:11:47 AM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 8/6/2015 6:11:21 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 8/5/2015 12:46:58 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 8/4/2015 11:57:22 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 8/4/2015 11:45:34 PM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 8/4/2015 11:45:03 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 8/4/2015 8:45:32 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 8/4/2015 8:42:51 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 7/29/2015 6:17:48 AM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 7/29/2015 6:17:31 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 7/28/2015 6:14:03 AM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 7/28/2015 6:13:48 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 7/28/2015 6:09:48 AM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 7/28/2015 6:09:30 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 7/21/2015 6:26:42 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 7/19/2015 6:14:47 AM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 7/19/2015 6:14:20 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 7/17/2015 10:11:52 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 7/17/2015 10:09:46 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 7/17/2015 9:34:00 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 7/8/2015 6:46:08 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 6/30/2015 7:19:04 AM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 6/30/2015 7:18:37 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 6/29/2015 5:42:55 PM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 6/29/2015 5:42:32 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 6/18/2015 1:26:10 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 6/16/2015 4:42:20 PM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 6/16/2015 4:42:03 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 6/16/2015 10:01:03 AM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 6/16/2015 10:00:37 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 6/15/2015 4:40:31 AM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 6/15/2015 4:40:06 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 6/9/2015 11:40:42 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 6/9/2015 10:09:25 AM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 6/9/2015 10:08:59 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 6/8/2015 6:27:55 AM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 6/8/2015 6:27:28 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 6/6/2015 11:11:09 PM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 6/6/2015 11:10:44 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 6/6/2015 11:06:18 PM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 6/6/2015 11:05:55 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 6/6/2015 12:42:27 PM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 6/6/2015 12:42:00 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 6/6/2015 6:54:36 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 6/5/2015 6:23:47 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 6/4/2015 6:45:35 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 6/4/2015 9:51:12 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 6/4/2015 8:21:37 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 6/4/2015 5:28:21 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 6/4/2015 2:21:20 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 6/2/2015 7:37:02 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 6/2/2015 6:10:06 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/31/2015 5:22:51 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/28/2015 6:53:14 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/28/2015 11:17:58 AM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 5/28/2015 11:17:49 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/28/2015 7:43:27 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/27/2015 5:11:22 AM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 5/27/2015 5:10:46 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/26/2015 7:31:34 AM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 5/26/2015 7:30:46 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/24/2015 6:03:38 PM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 5/24/2015 6:03:02 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/23/2015 3:10:47 PM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 5/23/2015 3:10:13 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/22/2015 1:24:49 PM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 5/22/2015 1:24:14 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/21/2015 9:56:27 AM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 5/21/2015 9:55:52 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/19/2015 10:45:31 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/19/2015 10:38:59 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/19/2015 10:12:45 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/16/2015 11:01:18 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/16/2015 9:36:18 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/14/2015 1:02:46 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/13/2015 4:28:23 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/12/2015 8:20:13 PM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 5/12/2015 8:19:39 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/12/2015 4:45:35 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/12/2015 9:14:06 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/11/2015 5:16:06 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/11/2015 4:59:43 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/11/2015 12:05:46 PM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 5/11/2015 12:05:12 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/11/2015 11:11:42 AM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 5/11/2015 11:11:08 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/11/2015 9:50:13 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/11/2015 6:12:34 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/11/2015 2:13:55 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/9/2015 1:46:41 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/8/2015 8:42:31 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/7/2015 8:19:54 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/6/2015 4:14:10 AM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 5/6/2015 4:13:56 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/6/2015 4:10:31 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/5/2015 9:33:26 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/5/2015 6:11:06 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/5/2015 6:06:07 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/5/2015 6:00:30 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/5/2015 3:12:23 PM Microsoft-Windows-PrintService 372 Printing a document "The document https://us-mg6.mail.yahoo.com/neo/b/message?sMid=3&fid=Inbox&so, owned by METALDIK2112, failed to print on printer HP Officejet 6700 (Network). Try to print the document again, or restart the print spooler.
Data type: NT EMF 1.008. Size of the spool file in bytes: 0. Number of bytes printed: 0. Total number of pages in the document: 0. Number of pages printed: 0. Client computer: \\METALDIKS-PC. Win32 error code returned by the print processor: 2147500037. Unspecified error
Error 5/5/2015 7:11:02 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/4/2015 7:07:22 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/3/2015 11:44:35 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/3/2015 5:31:32 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/2/2015 4:01:35 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 5/1/2015 7:29:46 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 4/30/2015 4:19:46 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 4/29/2015 6:32:25 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 4/29/2015 12:13:14 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 4/28/2015 4:11:34 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 4/23/2015 2:18:17 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 4/22/2015 12:21:49 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 4/20/2015 10:11:34 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 4/20/2015 12:35:16 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 4/20/2015 10:24:18 AM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 4/20/2015 10:24:04 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 4/19/2015 8:29:53 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 4/16/2015 3:56:15 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 4/15/2015 9:46:56 PM Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer HP Officejet 6700 (Network) with shared resource name HP Officejet 6700 (Network). Error 2114. The printer cannot be used by others on the network.
Error 4/15/2015 9:46:41 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 4/14/2015 9:01:55 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 4/14/2015 5:58:18 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 4/14/2015 10:45:08 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 4/13/2015 8:32:07 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 4/10/2015 10:30:49 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 4/4/2015 7:50:31 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 4/4/2015 3:11:08 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Circular Kernel Context Logger"" stopped due to the following error: 0xC0000188"
Warning 4/4/2015 3:11:08 AM Microsoft-Windows-Kernel-EventTracing 4 Logging "The maximum file size for session ""Circular Kernel Context Logger"" has been reached. As a result, events might be lost (not logged) to file ""C:\Windows\system32\WDI\LogFiles\ShutdownCKCL.etl"". The maximum files size is currently set to 20971520 bytes."
Error 3/31/2015 3:23:50 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Circular Kernel Context Logger"" stopped due to the following error: 0xC0000188"
Warning 3/31/2015 3:23:50 AM Microsoft-Windows-Kernel-EventTracing 4 Logging "The maximum file size for session ""Circular Kernel Context Logger"" has been reached. As a result, events might be lost (not logged) to file ""C:\Windows\system32\WDI\LogFiles\ShutdownCKCL.etl"". The maximum files size is currently set to 20971520 bytes."
Error 3/30/2015 7:22:08 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/30/2015 10:18:10 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/26/2015 12:00:35 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/25/2015 12:14:44 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/25/2015 12:05:20 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/25/2015 10:11:21 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/25/2015 12:09:33 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/24/2015 8:26:59 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/22/2015 11:55:37 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/20/2015 4:05:03 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/20/2015 3:05:22 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/18/2015 3:27:51 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/17/2015 2:24:06 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/16/2015 5:08:03 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/15/2015 9:27:00 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/14/2015 6:49:28 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/13/2015 9:40:09 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/12/2015 12:17:42 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/12/2015 12:15:49 PM Microsoft-Windows-PrintService 512 Initializing a print provider InitializePrintProvider failed for provider win32spl.dll. This can occur because of system instability or a lack of system resources.
Error 3/12/2015 12:15:49 PM Microsoft-Windows-PrintService 509 Routing print spooler command(s) The print spooler cannot start because the PrinterBusEnumerator could not start. Error code 0xd. This can occur because of system instability or a lack of system resources.
Error 3/12/2015 12:13:00 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/10/2015 5:10:13 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/9/2015 11:50:04 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/8/2015 2:01:30 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/7/2015 2:23:14 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/6/2015 4:58:33 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/4/2015 8:54:17 AM Microsoft-Windows-Dhcp-Client 1002 Address Configuration State Event The IP address lease 10.0.0.7 for the Network Card with network address 0x40167EB40D58 has been denied by the DHCP server 10.0.0.1 (The DHCP Server sent a DHCPNACK message).
Error 3/2/2015 10:36:21 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/2/2015 8:33:40 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 3/1/2015 4:01:11 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 2/26/2015 3:49:16 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 2/25/2015 4:00:23 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 2/24/2015 7:39:18 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 2/24/2015 1:55:10 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 2/22/2015 7:44:24 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 2/21/2015 5:57:11 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 2/16/2015 10:37:27 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 2/15/2015 11:13:47 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 2/14/2015 5:38:05 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 2/13/2015 10:13:39 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 2/13/2015 9:48:30 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 2/11/2015 10:09:28 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 2/10/2015 8:58:14 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 2/9/2015 9:12:51 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 2/8/2015 2:48:55 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 2/7/2015 8:38:24 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 2/6/2015 7:25:48 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 2/5/2015 7:32:42 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 2/4/2015 2:38:43 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 2/3/2015 6:21:33 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 2/2/2015 9:42:54 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 2/1/2015 5:45:52 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/30/2015 5:58:06 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/29/2015 2:12:53 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/28/2015 6:02:14 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/27/2015 6:23:06 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/26/2015 8:43:43 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/26/2015 10:19:40 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/25/2015 1:55:22 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/22/2015 8:56:53 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/21/2015 5:19:31 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/20/2015 12:54:00 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/20/2015 7:04:24 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/19/2015 7:50:36 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/16/2015 12:39:45 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/16/2015 12:19:30 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/15/2015 9:53:16 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/15/2015 1:21:19 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/14/2015 8:40:36 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/14/2015 3:20:07 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/12/2015 12:36:53 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/12/2015 12:12:28 PM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/12/2015 9:48:04 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/12/2015 9:41:32 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/12/2015 8:32:24 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/12/2015 8:23:20 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/12/2015 8:11:06 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/12/2015 8:01:08 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/12/2015 7:49:38 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/12/2015 7:25:53 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/12/2015 6:35:35 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/12/2015 4:43:15 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/12/2015 4:31:46 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/12/2015 4:26:25 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/12/2015 4:12:13 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/12/2015 4:07:39 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/12/2015 4:04:47 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/12/2015 3:40:02 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/12/2015 3:37:55 AM Microsoft-Windows-Kernel-EventTracing 3 Session "Session ""Microsoft Security Client OOBE"" stopped due to the following error: 0xC000000D"
Error 1/12/2015 2:09:07 AM Microsoft-Windows-Kernel-EventTracing 2 Session "Session """" failed to start with the following error: 0xC0000043"
Error 1/11/2015 11:12:20 PM Microsoft-Windows-Kernel-EventTracing 2 Session "Session """" failed to start with the following error: 0xC0000043"
Error 1/11/2015 9:55:44 PM Microsoft-Windows-PrintService 512 Initializing a print provider InitializePrintProvider failed for provider inetpp.dll. This can occur because of system instability or a lack of system resources.
this isn't really convenient for me at the moment but the above has provided some clues so thank you for posting the above.
Can you remove the AVG Tuneup Utilities application please.
Also please re-install MSE as it may have become corrupted:
Microsoft Security Essentials - Microsoft Windows
Look for command prompt in the start menu, right click on it and run as administrator. Type:
sfc /scannow
Press enter and await results.
Please run Malwarebytes as this app compliments MSE/Defender quite well:
Free Anti-Malware Detection & Removal Software
sfc /scannow
when I tried to run defender I get the error that MsMpRes.dll is missing, so it will not run. I went to all of the dll download sites and that dll was not on any of the sites. I am running sfc /scannow and letting it run overnight.
it finished quicker that I thought, results were: windows resource protection did not find any integrity violations.
Top Bottom
