Creative has released a Link Removed driver specifically designed to provide support for the X-Fi Titanium series under Windows 7 Beta.
If you own a SoundBlaster Audigy SE or another version of the basic Audigy model then used Windows Update to attain your driver. Creatives vista driver will cause blue-screens when used in conjunction with 7.
More links for Drivers:
I'll update this thread as and when new drivers are released..
Soundmax ad1888 driver problem solved!!
HI !! You all must be having problem that windows 7 is not detecting soundmax driver on asus board. On installing from cd that came with motherboard it says OPERATING SYSTEM NOT SUPPORTED!! :mad:
So the solution for this problem is.:D
Download this zipfile from the link Link Removed - Invalid URL
Extract the contents.
Findsetup.exe in it. Now, right click on the setup and choose option Troubleshoot compatibilty.
It will detect issues and search programs and you will be presented with a set of options.
Choose option it ran with previous versions and also choose need special permissions.
click next . And your setup should start.
Let the driver install . restart when...
you mean for the HMDI audio they should have been installed when you installed the the Video cards driver from nVidia
Creative has released a Link Removed for the Soundblaster X-Fi and X-Fi Titanium series. This update resolves a hardware/device detection issue under Windows 7. A 1.01.0099 Driver Pack has also been released for the X-Fi Surround 5.1 series.
Just check out your link and they only have Product Identfication Module Update from last year in Jan 2010.
(Release date : 12 Jan 10
This update resolves the hardware/device detection issue for Creative Sound Blaster® X-Fi™ and X-Fi Titanium series of audio devices in Microsoft® Windows® 7. For more details, read the rest of this web release note.
File Name : PID_W7PCAPP_US_2_11_01.exe
This update resolves the hardware/device detection issue for Creative Sound Blaster® X-Fi™ and X-Fi Titanium series of audio devices in Microsoft® Windows® 7. For more details, read the rest of this web release note.)
Creative has released a driver specifically designed to provide support for the X-Fi Titanium series under Windows 7 Beta.
Hello,
When i install the Window 7 In my PC. It install the drivers itself. I never install sound or video drivers separately
I choose winXP in the previous version, and at the end of the installation, I receivedthe message "Driver not found! Reboot and try again"
MB - ASUS M2N DH, factory driver from Windows Update in 2 channel mode. I want5.1! Texas does not release new drivers?
