SouthValhalla
Hey forum people!
Every time I try and copy files over my LAN (doesn't matter how big the file is or which computer I'm copying from) I get the BSOD. Ive tried to find the problem/solution myself but I may be in a little over my head on this one... Attached are my minidump files. Any help would be greatly appreciated as this is getting very annoying!
The recovery window upon restart says:
Problem signature:
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 7177
Additional information about the problem:
BCCode: 7f
BCP1: 0000000000000008
BCP2: 0000000080050031
BCP3: 00000000000006F8
BCP4: FFFFF800030FEFEC
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\112610-57423-01.dmp
C:\Users\Byron Will-Noel\AppData\Local\Temp\WER-72119-0.s
My system specs are:
Operating System
MS Windows 7 Pro 64-bit Build 7601
CPU
AMD Athlon 64 X2 5200+
RAM
3.0GB Dual-Channel DDR2 @ 373MHz 5-5-5-18
Motherboard
Gigabyte Technology Co., Ltd. M61P-S3 (Socket M2) Latest Bios
Graphics
SMB2330H @ 1920x1080
Sapphire ATI Radeon HD 57770 Latest Drivers
Hard Drives
245.12GB Maxtor Maxtor 6L250R0 ATA Device (IDE)
244.20GB Seagate ST325041 0AS SCSI Disk Device (SCSI)
Optical Drives
TSSTcorp CDDVDW SH-S223C SCSI CdRom Device
Audio
Realtek High Definition Audio - Latest Drivers
You're welcome. That's great to hear.
Yep, 10.10e is better for games anyhow, and that's not my word. It's straight from one of the actual driver developers, from one of his Tweet things. (I hate that site or any mention of it usually lol.)
Alright, you have a major issue with the RAM. It is currently running at half of its intended speed at 200 MHz. It should be 400 MHz. Go into the bios, make that change, save and things should be well. Keep us updated please. :)
(The machine is going to be a lot faster too.)
I set the BIOS to DDR2 800 but now, according to CPU-Z, it's 373.1 (or.2 ). There are no settings in the BIOS to change it directly. I tried setting their voltage from 1.8 to 2.0 in the BIOS but nothing has changed and CPU-Z actually still registers 1.8v?!
Does it make much difference? Any suggestions?
CPU-Z does not tell you the voltage in use. If it is reading 400 MHz, all is well. You should leave it set at 1.8V anyhow.
Change the FSB:DRAM ratio in the bios until it's right.
Tell us how it is going after doing so, please.
It was impossible to manually set my RAM up to its proper speed...but this weekend I installed a new HDD and CPU. After installing the Athlon II 445 the RAM now automatically runs at slightly over its recommended speed! All is FINALLY well! :) Thanks again to TorrentG for all the help!
