djghosttrain
I got my new laptop in the mail yesterday, and it has Vista installed on it. When I first booted up, I installed winamp, and added my library of music. It worked perfectly all day, and this morning, that is until I downloaded a windows update. I had to restart the computer, and winamp hasn't worked since. It just hangs right when you start it up... very frustrating.
I have tried uninstalling/reinstalling and with different versions, (even though it ALWAYS prompts for updates), but I get the same problem. The older versions aren't even compatible. Another weird problem I'm having occurs mainly in explorer, and mozilla, where the back/forward arrow keys get grayed out/un-clickable. What's worse is that occasionally the File/Edit/View, etc... tabs get grayed out as well, sometimes half of them. There is no reason for this, because when the back arrow gets grayed out, I can still go back if I use a keyboard shortcut (alt/left arrow key). Sometimes this happens with website links too (I couldn't compose a new email with gmail).
also, I should probably get a mouse, but whenever I type out something like this, the cursor will randomly move up, and I will end up deleting/blending a bunch of words together by accident. I think it's the touchpad, but I'm just typing normally (I had to type this whole thread out twice b/c of this)
Overall, my computer is STRUGGLING with vista, if anyone can help me, that would be awesome. my email address is [email protected]
It sounds like you're facing several issues with your new laptop running Windows Vista. Let's address each problem you've described:
Winamp Hanging After Windows Update:​
  • Winamp Issue: After downloading a Windows update, Winamp started hanging upon startup.
    • Try running Winamp in compatibility mode for an older version of Windows, which might resolve compatibility issues.
    • Check for any available patches or updates for Winamp that address Vista-related issues.
      Un-clickable Back/Forward Buttons in Explorer and Mozilla:​
    []Grayed Out Button Issue: Back/Forward arrow keys in Explorer and Mozilla becoming un-clickable intermittently.
    • This could be due to a browser extension conflict or a...
    • This could be due to a browser extension conflict or a compatibility issue with Vista. Try disabling extensions one by one to identify the problematic one.
    • Clear browser cache and cookies, as they can sometimes cause unexpected behavior.
      Grayed Out File/Edit/View Tabs:​
    ]Grayed Out Tab Issue: File/Edit/View tabs intermittently getting grayed out.
    • This could be related to a display driver issue. Ensure your graphics drivers are up to date.
    • Consider resetting the browser settings to default to rule out any customization causing these issues.
      Random Cursor Movements While Typing:​
    []Touchpad Issue: Cursor moving unexpectedly while typing.
    • Adjust the touchpad sensitivity in the control panel to see if that reduces the accidental cursor movements.
    • Consider disabling the touchpad while typing or using an external mouse to avoid this issue.
      General Recommendations for Improving Vista Performance:​
    ]Performance Enhancement: Vista is an older operating system, and performance issues are common. Consider these general tips to optimize performance:
    • Disable unnecessary startup programs.
    • Run disk cleanup and disk defragmentation regularly.
    • Ensure you have sufficient free disk space.
    • Consider upgrading to a more recent version of Windows for better performance and security. If these steps don't resolve your issues or if you need further assistance, feel free to reach out. I'm here to help!
