JohnL97231
Well-Known Member
For the past few days I've been getting the "Display driver has stopped responding and has recovered" error. Screen goes black for a while and when it comes back the error pops up.
I fear my graphics card is broken, but I hope not. My laptop has one of those switchable graphics boards. An Intel onboard one (power saving) and a Radeon 6600M (high performance). I only get this crash and error when trying to run applications that I have set or the system has set to use the high performance card.
I've tried updating the driver but this card is no longer supported and Windows says I already have the best driver.
I also tried this registry fix, but it didn't work:
1. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\GraphicsDrivers
2. On the Edit menu, click New
3. Select QWORD (64-bit) value.
4. Type TdrDelay as the Name and click Enter.
5. Double-click TdrDelay and add 8 for the Value data and clickOK.
6. Close the registry editor and then restart your computer for the changes to take affect.
A few days ago I tried a System Restore but it failed, and then it created more problems. Suddenly my OS (C:) drive only had 5GB of free space left. I remember I had a lot more free space before. Then after I tried undoing the System Restore, it failed again and left me with about 300MB of free space on (C:). I did a Disk Cleanup and only managed to regain 2GB of free space. With each reboot of my laptop, I seem to be getting back more free space on (C:). Now I have about 5GB of free space. I don't know how to free up more space on (C:).
I've meaning to do a clean install of Windows 10 since I upgraded from Windows 7 but I only have an expensive mobile data connection. I need to download 8GB of files? I simply don't have that quota right now. But I can buy it and it'll cost me RM30. I also don't have a thumb drive big enough at the moment. I don't think I can use my external HDD? I've tried the Media Creation Tool with my ext HDD plugged in but it said "compatible device not detected." Now with only 5GB of free space left on (C:), I can't even download the files. How do I get the Media Creation Tool to download to my (D:) partition?
I only started getting this error after updating my PC on the 24th or 25th of June. I got the dates based on the System Restore point. But now System Restore says I have not created any System Restore points. As mentioned, I only have mobile data so I don't constantly keep my PC updated.
Sigh.. really hope it's not the Radeon that is broken...
Well first off low disk space on your OS partition (C) can cause all sorts of problems. Looking at your logs I see that your system is having a lot of issues during paging (When data is swapped between memory and page file) if you right click on the "This PC" icon > properties and go to advanced you can try moving your page file to the D drive and see if that resolves your issue. This would also free up several GBs of space on your C drive.
The application block message may be coming from your AV software, I would test disabling your AV and re-launch the program.
>>>Hi John: Using the MCT tool from Microsoft website you'll need a minimum of an 8GB usb flash drive. When I first starting making W10 bootable flash drives; they only worked on a 16GB drive since they required just about 9GB of space. Since last year, the MCT tool will be able to create the W10 bootable flash drive on an 8GB drive. However, I still am only able to do it on a 16GB flash drive.:headache: An important thing to know. Also, you should be aware in a bug with the SanDisk Cruzer line of flash drives. They will not work with the Microsoft MCT tool and associated ISO file you download from the Microsoft site!! We've verified this problem on both W10 & W8.1. You have to use a non-SanDisk brand of usb drive in order to do this. We have tested so far on Verbatim and PNY with W10. FYI in case you go the USB drive route.<<<
>>>EDIT: Making the DVD disc using the MCT tool is vastly easier than making the USB bootable flash drive as you can see!<<<
Best, :encouragement:
<<<BIGBEARJEDI>>>
I've asked a friend's help to download the files for me. Will 1 DVD be enough? The best way is to use the Windows MCT, right?
Basically yes. They are usually around 4.7GB which is enough for the iso.
Sounds good.
Still no dump file. Should I trigger another error? How do I trigger another error? It's gone after I freed up space on (C).
Do you mean the issue has stopped since making space on the C drive? In that case then it's very possible your issue stemmed from having a full HDD. As BBJ explained above you need at least 25% of free space for Windows to work effectively.
Oh no... I wanted to ask why the dump file was still important after the error disappeared?
I mentioned in my reply to BIGBEARJEDI that the error was gone after clearing up space.
I'm so sorry for wasting your time. :frown:
I have another question though. Should my page file be on (C) or (D)? Does having the page file be on the partition that does not contain the OS affect performance?
S**t... Nope. The problem is still there. Tried to open a video with Media Player Classic and got the error again. Tried to force MPC to open the file and got a BSOD and my PC restarted. Something about Driver IRQL Insufficient or something.
Then after it rebooted, I couldn't get past the login screen and my PC restarted again. It said Critical Service Failed or something. Then it got worse. Twice during booting up, everything just froze. So I had to suffocate my PC and start it up again. The 3rd attempt was successful and... here's the log file. There is a dump file this time.
And now the error is gone again after I removed the registry fix and rebooted my PC. Hmm...
The dump is indicating the crash is originating from an undocumented function in your graphics driver. igdkmd64.sys. Looking on the device driver page, it doesn't appear this laptop officially supports Windows 10.
>>>Hi John; weirdness there for sure. I think it's a combination of things including the fact that your laptop does not have W10 WHQL driver support. I also wondered at your statement about Windows Media Player Classic; that's not the Windows Media Player native to W10 (WMP) is it? If so, and it's an older WMP especially from an older computer such as XP or Vista that ran the Windows Media Entertainment Center edition of Windows, THAT program is definitely NOT compatible with W10 as publicly stated by Microsoft on many occasions.:noway: They have discontinued all support for that platform. Is the file you are trying to open with the MPC program a music file (if so, which format, .mp3, .mp4, .avi, etc.) or a movie file. It would help us to know that. I believe you may be trying to run an unsupported app in W10 that's long been discontinued. If you didn't download that app from the Internet or a Disc to install it, then why exactly are you using it? This certainly isn't the only problem with your system, but it would be helpful to know exactly what you're trying to do with this program.<<<
Best,:)
BBJ
What should I do then? Or what can I do? It's weird that I only have this problem now. I've been using W10 for many months.
Best,:)
BBJ
I'm using the MPC version that comes with the K-Lite Codec Pack - K-Lite Codec Pack 12.2.6 Free Download.
I tried to open an .mp4 and then BSOD.
I think I'm going to try running Skyrim and see if my PC literally burns. Fingers crossed.
And again, I find it weird that I'm only having this problem now. Been using W10 for many months.
BugCheck D1, {98000000000, 2, 0, fffff80158b25621}
*** WARNING: Unable to verify timestamp for igdkmd64.sys
*** ERROR: Module load completed but symbols could not be loaded for igdkmd64.sys
Probably caused by : igdkmd64.sys ( igdkmd64+325621 )
Followup: MachineOwner
this error is caused by drivers using improper addresses.(usually) and looking through your drivers they do need updating.
I also notice your running Avast AV. This is known on occasion to cause the odd issue so we ask that you remove it and just use the onboard Defender during the period of troubleshooting.
I checked your system support page and unfortunately driver wise Dell isn't making any Windows 10 versions for your lappie:
Product not tested for Windows 10 upgrade
Dell is not testing or developing Windows 10 drivers for this product. If you choose to upgrade, some features, applications, and connected devices may not work as expected.
However as you have two gpu systems you could always disable the Intel device and just use the AMD card.
You need to update these drivers:
This one gets a special mention:
dtsoftbus01.sys Fri Feb 21 09:49:36 2014: Daemon tools well known for causing issues in Windows
HECIx64.sys Wed Oct 20 00:33:43 2010: Intel Engine management
IntcDAud.sys Fri Oct 15 09:28:17 2010: Intel graphics media accelerator
RTKVHD64.sys Tue Dec 14 09:14:04 2010 Realtek Audio
Now you do have access to some Windows 8 drivers which is less of a leap to win 10 than 7. If you open the support page under windows 8, look under chipset and install the top two drivers for your lappie.
See if you can update the audio driver too.
Try running these scans too:
File scans
Right click on the Start menu icon and from the revealed list choose 'admin command prompt'. Type:
sfc /scannow
press enter and await results
Post any new dump files.
File scans
sfc /scannow
Ok, I'll download them between 1am-7am (GMT +8) when I have a higher mobile data quota.
I think I'll uninstall Daemon Tools because I don't need it right now.
Ok John Thanks for the update. hope all goes well. Post back with any updates and please post any new dump files.
Yes it should do. I don't think there is a special removal tool and you just remove it as you normally would.
